#788864 by miopyk
20 Aug 2011, 21:33
Evening all,
I've got to go to Auckland next month and have been looking at the best way of getting there. Currently it looks as though it's a toss up between Singapore Airlines via SIN or Air NZ via LAX. Can't go with BA as they appear to be nearly twice the price (£7.5K) of the others.
Any experts out there want to offer any advice on which one to go with or recommend any other options.
Miopyk 8D
#788870 by tontybear
20 Aug 2011, 22:56
Not sure if this helps make up your mind but you can also fly NZ via HKG. The Business class trips in the random dummy booking I did were also cheaper via HKG than LAX
The NZ website also offeres a connection off the VS900 via Tokyo.
I think there are a couple of NZ TRs on here as well
#788904 by JCBR
21 Aug 2011, 13:55
As a VS partner you can also earn miles/TP with NZ and if you are in Business it is the same VS seat.
Whilst NZ does offer PE cabin it is not as good as the VS cabin but of course way better than Y !
#788907 by tontybear
21 Aug 2011, 14:07
JCBR wrote:As a VS partner you can also earn miles/TP with NZ and if you are in Business it is the same VS seat.
I thought the new NZ PE product (on the LAX route) had received stella reviews?
#788911 by JCBR
21 Aug 2011, 15:59
My expeience was the LHR-HKG flight (777) although I thought they used the same plane to circle the globe. Maybe they had an older verison this wek LHR-HKG.
#788916 by slinky09
21 Aug 2011, 17:12
tontybear wrote:I thought the new NZ PE product (on the LAX route) had received stella reviews?
It looked good, but apparently the legroom was dire, so they're in the process of removing a row of PE from the planes that were refitted!
#788918 by tontybear
21 Aug 2011, 17:24
Ah well at least they are addrsssing the problem rather than keeping it as is and dissapointing customers.
#788970 by Martin
22 Aug 2011, 10:20
Back to the original post.
I flew Virgin to Shanghai on VS250 then with a tight, but legal, 1 hr 25 min connection, changing to Air New Zealand NZ88 direct to Aukland. It all worked pretty well. My trip report is here
On the other discussion, I found the older ANZ PE seating quite good. They were economy seats so not as wide as VS, but in a config with loads of legroom and great cabin service.
Martin
#789008 by miopyk
22 Aug 2011, 18:31
Hi All,
Thanks for your views. I've booked Air NZ and am flying Business Premier via LAX.
I'll let you know how it goes.
Miopyk 8D
