#259678 by mitchja
21 Jun 2009, 14:26
This is just something to be aware of if you are roaming with your iPhone (even with data roaming switched off).
You are still able to send MMS's with data roaming turned off (even though the text under the data roaming option in settings states you shouldn't be able to). I wonder if if just stops you receiving them?
You will get charged a data roaming charge as well as the MMS coming off your normal text allowance in blocks of 4 (contract users).
From the US, sending 1 MMS cost me 0.43p. Now I realise, that that exactly going to break the bank but just something to be aware of.
#718962 by locutus
21 Jun 2009, 14:45
If you turn off data roaming, you should still be able to send and receive texts and MMS, as they aren't considered data. This is how every other phone seems to operate.
#718963 by mitchja
21 Jun 2009, 14:53
I'm not sure if it should or not. UK iPhones use the same new APN for MMS (idata.co.uk) as for cellular data so in theory, having data roaming turned off should prevent sending MMS's but it seems it doesn't.
If you have the 3GS and you send video as MMS (which I think you can do) your roaming charges will likely be higher as well.
It does state under the data roaming option in settings that 'Turn data roaming off when abroad to avoid substantial roaming charges when using email, MMS, web browsing and other data services' [:?]
#718964 by Scrooge
21 Jun 2009, 14:56
Thanks for that info.
Of course I do have to ponder the thought that isn't it great that a UK iPhone can send an MMS in the US, but a US one cannot.
#718967 by mitchja
21 Jun 2009, 15:07
I was sending one from on the ferry to the Statue of Liberty yesterday and it was generating a bit of interest from an American guy also asking me how I was able to do it!!!
