#16264 by G-VROY
14 Nov 2006, 13:28
I allways thought that Virgin never used 767's, but i was looking on ebay and found a 767 VA safety card. i then searched for a photo and found this Image I searched but couldnt find anything on here, or under retiered a/c. could someone shed some light on it?
#147572 by mcmbenjamin
14 Nov 2006, 13:36
G-VROY: The Boeing 767-200 were used on the Manchester-Orlando route. They were on wet lease and only used for one summer.
#147574 by G-VROY
14 Nov 2006, 13:38
ok thanks for that[^][y]:D
#147575 by Neil
14 Nov 2006, 13:46
VS only ever had 1 B767-31AER From Sept 1996 until March 1997 which they leased from Martinair, Reg was PH-MCG.
Neil:)
#147577 by KenJohn
14 Nov 2006, 13:56
What's a wet lease ?
#147578 by ShropshireLad
14 Nov 2006, 14:03
So, it was sometime after this that:
4 Engines 4 Longhaul
started appearing on the side of VS aircraft?!:D
Plane in the pic looks very much like a 762 to me, so evidently not the same as the 763 leased from Martinair. Were there -200s and -300s leased at various times then?
Jim
#147579 by G-VROY
14 Nov 2006, 14:03
have they done this with any other a/c?
#147580 by Neil
14 Nov 2006, 14:03
If you take a look here it explains what it means.
Neil:)
#147583 by Neil
14 Nov 2006, 14:23
The a/c in the pic is the one leased from Martinair as per my post above. If you look hereit confirms this.
Neil:)
#147594 by ShropshireLad
14 Nov 2006, 14:59
Neil:)
Thanks for the bigger pic - from that I can see it's a 763 now - extra fuselage section fore of the wings. Usually there's an extra door there - but obviously not in this config...
#147604 by jaguarpig
14 Nov 2006, 15:43
You learn something everyday on here, never knew VS ever operated 767s[:0]
#147607 by mcmbenjamin
14 Nov 2006, 15:50
Well normally the flight crew (pilots, navigator and such) are from the company that owns the plane. Like when BMI's IAD flights were operated by Icelandair, the flight crews were Icelandair pilots.
#147648 by Howard Long
14 Nov 2006, 19:19
They wet leased a 747 (-200?) from Air NZ to run, ISTR, the BOS route for a few months. A buddy of mine, since retired, used to be a Captain on the route. He still keeps his really, really old Virgin Crew baggage tag on his flight case: it must be fifteen years old.
When I last met him at home in Auckland about six months he commented on how much he enjoyed that working that route, while coincidentally mentioning how young FA's on VS all seemed...
Cheers, Howard
#147669 by VS045
14 Nov 2006, 21:36
This plane does look to be somewhat a "hybrid" with two over-wing window emergency-exits instead of a door just forward of the wings.
VS.
#147698 by VS045
14 Nov 2006, 23:00
Having had a look around on a.net, most 763s seem to have two doors forward and two doors aft of the wing. Delta, however, seems to have theirs in the same config that VS/Martinair did.
VS.
#147740 by willd
15 Nov 2006, 11:05
VS.
Ahhh the good old Martinair 763!
The two over the wing exits i believe is an option that can be done instead of a 2nd door further forward. Its down to the carrers preference.
VS did lease other aircraft.
A 737 was leased (G-UKLB) from Air UK Leisure to operate the LGW-ATH route during the early 90's. Obivusly this route was part of the partnership with SEEA at the time. The SEEA deal was originally that SEEA operated the route in VS colours. SEEA went bust in the late 90s and VS took the over the route fully (hence GOUZO getting a UK registration). VS of course stopped LON-ATH post 9/11.
