I know it allows Clubhouse, and I assumed it allowed Revivals, but after looking at this: the-toolbox/fare-codes?code=G it isn't explicitly stated in there like it is for all of the other Upper fare codes.
-Matt
-Matt
stoneman wrote:Don't get your hopes up too high. It isn't anything like the Clubhouse.
hat wrote:stoneman wrote:Don't get your hopes up too high. It isn't anything like the Clubhouse.
no its not, i struggle to spend much more than an hour there. once you've showered & had breakfast there's nothing else to do other than read the papers or watch telly. the showers are very nice though, & spotlessly clean, you get your own bathroom with hand basin, tolet & walk-in shower
tontybear wrote:Yes revivals is not the CH but it IS a much nicer place
locutus wrote:If you're in upper class, you get all the benefits, so yes.
DocRo wrote:locutus wrote:If you're in upper class, you get all the benefits, so yes.
There is an exception of which I was unaware until recently. As I was leaving revivals, an elderly couple were being refused entry. They had been op-uped to UC (lucky) and were told they did not qualify to use revivals without paying.
mattdell wrote:DocRo wrote:locutus wrote:If you're in upper class, you get all the benefits, so yes.
An upgrade from PE or Economy wouldn't be a G fare, though, would it?
Still doesn't make sense for them to be denied, especially if they explained they didn't take the breakfast service on the plane when they had been promised a meal on the ground in revivals. n(
There is an exception of which I was unaware until recently. As I was leaving revivals, an elderly couple were being refused entry. They had been op-uped to UC (lucky) and were told they did not qualify to use revivals without paying. I thought reception handled this poorly as the crew had informed them they could lie in, miss breakfast service and get something in revivals instead.
Revivals was far from busy and still an hour or more from closing.
Users browsing this forum: Google [Bot] and 168 guests
